Getting ready for summer road trips. With a family of 7 on board, the ass end really drops. Stock rear springs w/ MAF 30mm spacers. Stock front torsion bars cranked to 21.5" Fender lip to hub center, 1" rake rear to front. Fox 2.0 Shocks. No extra weight (stock plastic bumpers all around, for now). All good til, everybody piles in.
Been wanting to add AirLift bags for a while. Studied this thread repeatedly and ordered this kit...
AIR LIFT 60808 1000 Series Rear Air Spring Kit
Quick observations. Bags actual length 9.375" tall, very close in diameter to the ID of the spring. Kit included urethane spacers (black hockey puck), air fittings/tubing, sheet metal heat shield x2 (did not use).
Picked up a step drill bit from Harbor Freight ($20 for 2 pc Kit). Bigger of the 2 was up to 1.375" diameter, but will hit the axle tube before plunging that deep. Resulting hole was around 1" (didn't stop to measure) I used the sharp side edge of a flat bladed screw driver to debur the bottom side of the hole (scraping around the inside lower edge). Finished with a Jewelers file.
However, I was really wanting to line the hole with a plastic bushing of some sort, since rubber grommets/fuel line seems to be too grabby. The stock 1/8" AirLift black tubing was more flexible than other pneumatic poly tubing I've used, so I decided to try splitting down the length and lining the hole with it (see pic). JB welded it in place. Installing it was very finicky, messy, and added time to the job to let the epoxy to set up a bit. Jammed a 17mm socket in there for a while to seat the JB (pic). The hose slides extremely easy through the new hole. Hopefully, it holds up over time.
I used the supplied spacers at the bottom, although they were not a good match dimensionally with the bag, coil, or barb/tube fitting. I'll trust the manufacturer, but keep an eye on it.
I left enough slack in the line for the bag to be pushed up to the top spring perch at full droop/extension. I routed each bag's air line to the supplied "T" in the center of the axle, zip tying to the hard brake lines. Then routed the single line along the flexible Brake Line up to the frame cross member. Ran the through the frame back to the drivers side rear bumper. Mounted the Schrader valve through a bumper tab pointing straight down.
For those of you running stock + 30mm coil spacers...With the truck on the ground, this length bag just touches the perches top and bottom. I need to play with it more, but appears, adding and subtracting air immediately raises and lowers the truck. Kind of what I was hoping for.
"Upload File" not working right now. Will post pics a soon as it decides to not error out...
