air down
Orange County
What do you guys mostly air down to? Sunday was the first time I air down my tires. I low them to 6 and 7 psi. Im on some 35x12.5 mt/r They grab great. The fj40 is about 5000 lb or about so. And its a 15x9 wheel Is that a good psi? I put the front to 6 because they are more wear out. the back are new so I put them to 7psi. What you guys low down to ???
Eric
W/O beadloscks I go to 8lbs usually with no prob's I do have a set of double beadlock wheels and I can go to about 4lbs with mr's on em' any more and they look a little too flat for me.
I run around 12-14... 14 lately now that my Stauns are tuned in.
If I am running on washboards I run a little less, but I haven't gone as low as some of the numbers already listed.
Rezarf <><
Usually 12-14 as well.
Around home, we wheel in sand, 14 seems to be the best compromise. Higher you sink, lower you plow, the sand can get pretty dry and loose around here.
