Who's running what and any feedback? My OEM bushings are worn out, so I figure it's time to upgrade. Looking for some first hand opinions!
I ended up picking up a brand new in the box set for $400 shipped.
I have about 2 years on the SPC's. They allow you to adjust both camber and caster with just the balljoint. You can basically adjust the inner mounting bolts for little to no bushing binding. Being able to adjust caster to 4+ degrees has been awesome for highway speed traveling... with great stability and return-to-center steering characteristics.
I did torque the balljoints down to 150 lb/ft and once, was able to knock the camber off alignment on an exposed tree root on the trail, at speed. Be sure to carry the correct socket to get it back into alignment. Hasn't been a problem since. I might suggest scraping/sanding the powder coating off on those ball joint to UCA contact points, prior to install, for better grip.
I don't think there is an ideal, off the shelf, UCA for the 100 yet. But given the choice today, I'd select the SPC's again.
Yes, I am liking it w/o issue. However, steering effort is slightly increased, which I am fine with. Tire/wheel offset combinations that are already tight on clearance at the firewall will have slightly tighter clearance with the added caster. My last alignment specs say 4.5 and 4.1 degrees.Can I assume your are running 4° of caster and liking it without issue?![]()
I was going to start with 2° but thanks to your feedback Im in for 4°. Being part time Im a little lighter anyway and I like the feel to caster alot.![]()
