Klaus, I'd be curious to know if/where you locate said wiring.
Thanks
I only found an extra plug off the o2 sensor. Anyone know what that does? I looked in the wrong place. Looks like its more toward the rear axle.
Thanks
Can an LX guy give pic/location if said plug so that the 100 guys can look for a match?
Darn. My 1999 LX does not have connectors. My wife's new outback has that lights and I find it useful. Especially when going to the farm at night.
Putting pfrans LEDs I to the doors helps some.
Its at the front on mine...
I bought some flexible led strips that have adhesive backing. Wired them behind the door panel with the courtesy lights after running the wiring through the same opening. The strip begins at the door light and extends forward about six inches on the face of the door panel.
Gives lots more light when the door opens to see where you're stepping.
Any update on finding that harness routing and/or part number?
I just got an idea that would require more effort but accomplish the same effect. Get 4 of these linear lights and wire them into the dome light wiring with a relay. The dome light will trigger the relay to power these as courtesy lights. In theory they should fade in and out just like the dome light but they would act as courtesy lights. Thoughts anybody?
This is just a crazy idea I thought of when I looked at these lights, I don't know how bright they actually are.
If you install a relay (which you should), there will be no fade up and down of light- relay is an on/off “thing”![]()
