Adding courtesy lights to sliders
Doesn't require a relay, but it's smart to use one so that you don't put extra stress on the dome light circuit. LEDs don't even draw that much power but it's better safe than sorry imo.
Cool, thanks for the explanation @FlammableFishie, I'd guess that with LEDs in the dome lights already there can't be too much stress on that circuit... Plenty of folks have added additional strip lighting to the rear hatch, without a relay I'd guess.
Off the wall question, but does anyone know what the part number for the plug is? I'd rather buy a new male plug than cut the one off the running boards if I could.
20130722_215208-jpg.784376
To answer my own question, this is the female plug coming from underneath the body that plugged into the factory running board light.
I was unable to find the male counterpart, so I cut the factory plug off and attached it using waterproof connectors to both the aftermarket LED lights and the stock running boards in case they ever go back on for some reason.
I bought some $15 LED lights and filled them with as much silicone as I could and bolted them to the factory running board mounts underneath the truck.
Lights:
https://smile.amazon.com/gp/product/B00OST5TAU/?tag=ihco-20
connectors
https://smile.amazon.com/Deutsch-2-pin-Connector-housing-Terminals/dp/B00B4F9EXY/?tag=ihco-20
