- Joined
- Dec 24, 2003
- Threads
- 136
- Messages
- 3,559
Just added his contact info in the other thread. Post #43
https://forum.ih8mud.com/80-series-tech/238896-hood-louvers-retro-fzj80-2.html#post4005330
Ahaa! Thank you, thank you!
Citadel ,what vents did you use? MIke
Yes, you have to cut into the bracing, no it does not adversely affect the hood.
Until the vehicle is involved in a front-end collision and the hood collapses in a manner other than it was designed to do. Hopefully the hood does not come back through the windshield.
That being said a hood with chopped braces would probably fold sooner than an un-cut hood. It is not a good idea to add bracing to a hood because it will be more likely to get shoved into the passenger compartment instead of folding up.
murf said:Agreed ^
The heat that quickly radiates out of my hood vents from the Supercharger is enough to see with the naked eye. I equate it to running around the room until your good and sweaty, throw a blanket over yourself and fall on the ground to trap in the heat...
Heat soak just adds to total underhood temps and in Arizona, we need all the help we can get. One thing I did determine this last weekend is that the intake temperatures vary as much as 10 degrees cooler with a snorkel vs without. I do not run one but both our 80's run Scanguages and the snorkel brings in cooler air. i would imagine this would mane more efficient performance due to the cooler intake air.
I still am not sure if I really wanted a snorkel in dry AZ but now wonder if it would be good at least for this fact.![]()
aluminum ceramic coat the exhaust manifolds and air filter housing as well as add a snorkel to reap the most cooling benefit.Where can one get aluminum veramic coating done. Is this a do it yourself venture or professionally installed?
Yes, between the highly juiced fan clutch, 3F fan, hood vents, immaculatly maintained cooling system, and JDM fan, I agree it is a "whole package" success. Just one item wont make all the difference but together....
Im interested in the coating idea and see if that can add to the help and bypass the snorkel for now.
Thanks, Murf
Agreed ^
