Beautiful fender trim/chop!Jason is now sitting on 37’s
too tired to explain everything I did over the last four days
Here was his first message when I asked him how it felt… “Yes, was really windy when I first started out. That was pushing me side to side a bit, and I noticed the swaybar being deleted. However, I put it in sport mode, and that took care of it. I was in comfort previously.”Dang hows the view from up there?!?
Is it tippy at all?
Later on he said it felt “taller”, but the context seemed to indicate it was a good thing![]()
I know it’s weird but you can feel every 1/4” of height addition. Every bit really does count lol, no diddy.
Yes, we did the 1.5” kit.@MTKID , what size BL did you install on Jason's rig? I presume 1.5"?
This is something I was really keyed in on. Like you, I can feel every bit of suspension lift, with dynamics and CG.
Because of that, I only BL lifted 0.75". Happy to report after putting it through the ringer this weekend over super tight mountain roads and 60MPH drifts in the desert washes, the BL lift had nominal impact. That's the best kind of lift IMO where additional clearance can be made, while keeping so much goodness in handling and CG. I'm trying to build my truck where I can have more clearance at normal height without having to resort to high mode as much. Normal has way better sidehill stability and puts down power better. While having high mode in the back pocket for more extreme clearance when needed.
This past weekend. Even with the RTT up top, stability was solid.
Give me some upskirt shots will you? If anything i may be simple enough to do this just for rear shock accessibility.
Side note. I actually test drove an R1S recently and was very, very happily surprised. Did you by any chance wheel it? What your thoughts?
1” doesn’t help much, still not enough room to reach rear shock through the wheel well… and I just tried…
We will probably offer 1” and 1.5”. But it’s a lot to unpack, how to provide instructions and cover all the bases. I can’t be taking a ton of phone calls to answer questions when people don’t have any experience with body lifts. And I do appreciate good customer service, so I want to assist, just need to wrap my head around how much work it honestly is. It’s not for the faint of heart, but, at the same time it’s not rocket science either.Can’t wait for a write up on either of these installs (.75” or 1.5”)
We will probably offer 1” and 1.5”. But it’s a lot to unpack how to provide instructions and cover all the bases. I can’t be taking a ton of phone calls to answer questions when people don’t have any experience with body lifts. And I do appreciate good customer service, so I want to assist, just need to wrap my head around how much work it honestly is. It’s not for the faint of heart, but, at the same time it’s not rocket science either.
I’m probably just a little shell shocked about what I just did over the last four days. The body lift was only a portion of what I did for Jason.
I hope to start a specific thread for these soon. And Paul can share his experience and there can be a general place for specific questions that I may forget to include in the first set of instructions. It’s inevitable there will be a few.
It is no small feat. And explaining it to the less mechanically inclined is the biggest challenge of all.Thats just sidewall flex. Don't worry they make 37's for 22" rims too.I know it’s weird but you can feel every 1/4” of height addition. Every bit really does count lol, no diddy.
At first thought yes. But I think it's more about "stance," - offset, and wheel width than purely tire width. I think 18's are probably my ideal balance for upscale looking and wheelability. However the drawbacks are that tire and wheel combo is probably 10lbs heavier than @MTKID's 40's. Also insane there isn't an RCV axle upgrade option.
