I think I’ve seen it noted that the handheld antenna setups don’t work that well. A mag-mount antenna like a Wilson Little Wil should do the job just fine. Pair it with the Midland 75-822 CB and you’ll have a setup you can completely add or remove from your truck in like 5 mins. I think we just dropped the antenna wire through the sunroof last year with that setup.I need to pick up a cb before the trip as well. I'm wondering if a handheld with its attached antenna will work for the trail rides since we will be in close proximity or if I need to get a antenna mounted or a magnetic one for the roof. I'm fine either way but being able to use the handheld without mounting an antenna would be one less thing on list of things to do.
