Registry 8x Series V8 Swaps
Vehicle Registries
Not sure if you misunderstood or if I did. But if he changed the MAF housing pipe diameter it will absolutely cause an adverse effect. OEM parts have a certain piping diameter that would allow a certain range of airflow to be read accurately by the MAF sensor. However, if you change the size of the MAF housing then not all air that passes will be measured. In turn it won’t be able to read how much air is coming in after a certain point. This is usually around 5 volts. When you increase the diameter of the piping, you allow more air to flow over the 0-5 volt MAF sensor without overwhelming it with more air than it is designed to read through the change in electrical current as air passes over it.
Ya I agree. You can't change the maf housing diameter without getting the ecu flashed for the new diameter
Yes, exactly, Flashed/tuned.
Only quick fix here is if he keeps the larger piping except for the MAF housing. Reinstall the original MAF housing and put on reducers to go from 4" to 3.5"
Did you see that he used the Toyota housing like mentioned above?
No, from what I saw, he showed he used a larger 4" diameter housing and posted a pic of it.
@NCFJ So I know you guys have seen and worked on a ton of swaps, therefore I have to ask, what's the dislike for? I diagnosed the problem correctly so???
Because I do not agree. I think you made a very broad statement. I am no expert for sure but I have had my share of ECUs flashed for swaps and not once was I asked what size the intake was. I've fixed a couple botched swaps where I installed a larger intake system with zero negative response. I do not doubt that what you stated has indeed occurred but I do not see it as a singular cause for the OPs issue. Tommy also made a good point, sometimes just unplugging the system for a little while and hooking back up can work wonders. I do not pretend to understand all the computer related issues, I just try what others have reported worked for them and more often than not, it works.
Intake pipe diameter is not the issue, MAF housing diameter change was. That's all
Not arguing here but did you diagnose the problem correctly we haven't heard back from the op witch is normal. And yes I wasn't talking about the change in the size of the maf housing was talking about the real pinch point of air coming into the airbox is the inlet that goes into the inner fender well. Anyways I don't usually use a maf sensor anyway. @McDowra you get this figured out?
No argument here, just talking from experience. I use to build intake systems for years on all types of swaps. I know that's the issue.
Cool on landcruisers or something else just curious here and of course I would like to see a picture of your work.
In the gym at the moment and pedaling away so my hands are free. So let's chat.. My father was an automotive electrician for 38 years before he retired. So I naturaly grew up always around them and obviously took an interest in the funner stuff like performance upgrades. Opened up my own place back in '98 as a Performance and Accessories store in SoCal. We worked on every car manufacturer, didn't discriminate. However I have always been a Toyota fan boy, again because of my father. Got into Land Cruisers in 2010 and have since worked on hundreds. Still own 4 Cruisers and 1 with an LS swap. Haven't posted in years on our Instagram page but you can see some of our shop stuff. Login • Instagram - https://www.instagram.com/2kracing?igsh=YzVkODRmOTdmMw==
Word
Following your page now
Word
Appreciate your patience with me. My wife says I always come off as being a dick. And my wife is always right. At least that's what I tell her.
I’ve been called worse. My gf calls me an a****** all the time... most of the time I'm just being honest and to the point so a****** it is but internet bs and text make everyone a dick or a****** and most of my friends are the same as me and I've known them from way back the rest come and go and I'm fine with that. Believe me we are not alone right @NCFJ You old fart lol
I have not, gonna have it towed to my tuner will let you know what he finds
100% bolt-in AC hose kit for Gen 3/4 truck compressor (and assuming using 4l60e/6l80e with stock crossmember/transfer placement) will be available to order soon. Will be a suction hose and high pressure hose (from compressor to condenser) already crimped to length, with adapters for firewall and condenser (with optional trinary switch port on condenser adapter) and compressor adapters.
ETA?
