See my email Kevin?
This might be useful here too:
There was a split in seal part numbers for the 1983 model year, up to October of 1982 (which would have been called a 1983) and later.
1980.08-1982.10 - BJ42, FJ40 90311-48002 which the seal manufacture has superseded to a 90311-48009 (74mm)
1982.10-1984.10 - BJ42, FJ40 - 90311-48007 (Measures 72mm OD)
The 90311-48009 (our part# TC48009) is the same as the front output seal so it will have the dust lip on it. Obviously this won't mate against anything inside of the t-case but it won't hurt either. We ran into this a couple of years ago with the seal manufacture and the assembler of the kits in Japan, they stand by that application. If you prefer a double lip seal in this spot without the dust lip, the Toyota 90311-48022 should do the trick. I don't have one here in stock to measure but that is what my notes indicate, unfortunately that is a Toyota only part, NOK and the other Japanese seal makers we use don't have an application for that, rather they reference back to the 90311-48009. I'm going to order the 90311-48022 to see if that has the dimensions (74mm) we want for this application.
Now as for your kit, it should have had a second 90311-48002 (which they supersede to the 90311-48009) thus giving you a total of two of those? I double checked a couple of the kits we had on the shelf and sure enough they had 2 of the 48009, sounds like yours might have been skipped over, sorry about that. Lemme know if that helps out.
