80 series with a Four Wheel Drive Camper?
"the whale's vagina", CA
I am considering turning my trail truck into a modified chassis with a used 4WD Camper on it. Any thoughts on this and if it is possible? I would most likely chop out the second row and make it a flat bed and then go from there. I love my truck but want something different as far a more comfortable camping but still able to do 4x4 trails. Seems like a great idea but never seen it done and there might be a good reason for that. Unsure if the 4wc would be too wide? Has anyone considered this or know of someone who has done it?
Gracias,
N
Kinda like those?
Personally, I would buy a 1 ton, put four wheel camper on it, and then you also got a tow rig....
I think Center of Gravity will be off, unless you stretch the wheelbase.
@White Sheep rig is a sweet. Using his rig as an example, if you stretch the bed on his rig, the COG of a camper will be way behind the rear wheels.
A couple people have put complete dolphin cabs on the 80 chassis. I saw one example of a 60 that did a cab chop and integrated the camper onto it, though I think they cut it after the first row.
Anything is possible if you're determined enough, but the above advice is well given about COG. What kind of trails do you intend to run?
There are bunch of these things running around. I think some of them are really cool. This one was for sale in Tucson a while back-- I wanted to make time to go see it, but didn't manage it before it sold.
Anything you do will have some kind of trade off.
Some of those campers look really cool.
My guess is there all overweight and breaks and power are compromised !
Maybe maybe not - This was the same weight as my 80
I've seen a few of these done over the years, and honestly the biggest headache is always the frame - not the camper itself. The 80 series unibody is tough, but putting a hard-mounted camper body on it means you're creating a leveraged moment arm that the stock floorpan was never designed to handle. Every rockflex, every river crossing, every hard rut puts twisting force through mounting points that want to fold.
If you're set on going this route, the key is a full subframe that ties into the existing frame rails at multiple points - not just bolt-in plate to the floor. Something that spreads the load back toward the engine and rear diff crossmember, not just relying on the sheet metal floor. Most of the "chopped up 80 with a camper" builds I've seen that are still on the road did exactly that.
The width thing is real too. Most 4WD truck campers are built for 3/4-ton trucks with fender flare clearance. An 80 is narrower and you WILL hit trees on tight trails. That's assuming you can even fit it without the camper eating into your approach/departure angles.
If you're not married to the idea of keeping your current truck, the cab-and-chassis route the others mentioned is genuinely the better path. No compromises on frame, full payload capacity, and you can still run it hard.
Gracias,
N
Extend the wheel base. In my opinion otherwise it is funky with to much overhang behind the rear axle.
Cheers
Mine chopped with wheel base extended. It will will be around 120-122” wb when done. I will cut off a lot of frame behind rear axle too.
Cheers
