For Sale Mebane, NC: Chopped LS swapped 94' Toyota Landcruiser
White Sheep
Darren
Okinawa, Japan
Year
1994
  1. 80 Series
Mebane, North Carolina United States
Mileage
12345
Color
White
94" Toyota Landcruiser, with a LQ4 LS (6.0) engine/4L80E Transmission. Chopped with custom tray, 4" Radius Snorkel/airbox, 4" lift, 37" Maxxis Trepador tires.
Same post just cleaned up to make it more relevant.
Most of the specs -
Engine/Transmission:
- Gen III 6.0L engine (LQ4).
- BTR Stage 2 Truck Cam Kit.
- Michigan Motorsports Timing Chain, Cam Sprocket, Crank Gear, and Dampner.
- ARP cam bolts 134-1003.
- Michigan Motorsports LS7 Lifters Set.
- Wiseco Pro Tru Street Pistons.
- Brian Tooley Racing LS9 Cylinder Head Gaskets MLS Pair Turbo Multi Layer 4.100 Bore.
- Melling 10296 oil pump.
- Michigan Motorsports Camshaft Thrust Retainer Plate.
- Mark's 4WD Oil Pan and Sump pickup kit.
- ARP 134-3609 head studs bolts.
- Gates 160° thermostat.
- ICT Billet LS Truck OEM Location Alternator/Power Steering Bracket LQ4.
- 4L80E Transmission.
- Mark's 4WD Transfer Case adapter.
- ARP Bellhousing Bolts ARP-134-0902.
- Selkirk Off-road motor mounts and crossmember.
- Walbro GSS342 Fuel Pump + 400-766 Installation Kit.
- PSI wiring harness.
- FIC 34LB truck injectors w/adapters.
Suspension/Wheels/Tires:
- Slee Rear bump stops.
- Slee Front Swaybar extensions.
- 17" Steelies.
- Method NV 305 titanium 17" wheels.
- 37" Maxxis Trepadors.
- Landtank extended rear lower control arms.
- Dobinsons adjustable lower upper control arms.
- Dobinsons adjustable front panhard.
- Fox 2.0 shocks.
- RVC Chromoly front axles.
- Slee Billet Front Control Arms.
- Slee 4" springs.
- Land Cruiser Phil's heavy duty rear swaybar links.
- Tatton front and rear double cardon drive shaft.
Body/Bar work/Recovery:
- Chopped.
- Sunroof delete.
- Antenna delete.
- Quad headlights.
- 4x 4x6'' Demon LED Headlights Kenworth Freightliner FLD120 Peterbilt 379 378.
- Custom tray
- ARB bumper.
- Warn M8000 winch.
- White knuckle sliders.
- 4pc 4x6 RGB LED Headlights Hi/Lo DRL.
- Toyota Pickup 2 Door Standard Cab 1984-1995 back window.
- Raptor Lined (tintable), bright white with metallic flakes.
- Rampt Customs front axle truss.
- Arcworxs knuckle gussets.
- Barnes 4WD short receiver tube.
- custome flare guards.
Interior:
- Glove box grab bar.
- Wit's End fire extinguisher mount.
- Lizard Skin sound deadening and Ceramic Insulation.
- MAT66 ProBlack Car Sound Deadening Mat.
- TruFit vinyl flooring.
- Corbeau seats.
- Element E50 Fire Extinguisher Roll cage Mounting Bracket Kit.
Electronics:
- Dakota Digital GSS-3000.
- Dakota Digital SGI-100.
- WOLFBOX G850 4K Mirror Dash Cam,12'' Mirror Dash Cam Front and Rear.
- ATOTO S8 Ultra 10.1.
- Scan Guage II.
- Viper alarm system.
- Auxbeam 8 Gang Switch Panel GA80.
Flaws:
- No AC. Everything is plumbed up with freon, but i think the evaporator is clogged.
- Its loud (exhaust routing and muffler will fix).
- If I was to do it again, I would use a mechanical fan, instead of electric fans.
I have a build page with everything from purchase, chop, engine swap, to current: Builds - Project Rehab (Chopped LS Swapped 80 Series) - https://forum.ih8mud.com/threads/project-rehab-chopped-ls-swapped-80-series.1286025/
Asking $24,000. obo
No. Everything is hooked up, just didnt feel like pulling the dash. I now live in Japan, but the LC is in NC.
