ARCHIVE 80 Series LED Madness!!!
Status
Not open for further replies.
Paypal sent for doors and map light. Thanks!
PLEASE READ:
A lot of people are sending PayPal payments that just contain the buyers real name. I have no idea what you want, what your Mud name is, and where you want it shipped. There is a section on the buyer side for notes to seller. You need to enter the following information in this area::
-Mud name
-Real Name
-kit number (80 #3)
-Ship to address
With the amount of volume I am working with, it is a royal pain to play detective and comb through multiple threads, forums, PM inboxes, personal email and Paypal transactions trying to figure out that John Smith is really MudLVR69 and that he wants the 80s kit #3 shipped to 305 Nitto Trail, Mudville, LA 71432
...And don't come back at me with the "you should know what kit it is by the amount sent" response. Payments come through in varying amounts depending on how the user tags the payment. I am also selling kits for different makes and models and there is some overlap with kit pricing.
Other than that, thanks for making this a successful thread! I look forward to providing you all with as many kits as necessary. I am also looking into the whole rear exterior thing and have samples en-route.
PLEASE READ:
-Mud name
-Real Name
-kit number (80 #3)
-Ship to address
I'd say at the least, in our defense, instructions never instructed to say it was for a 80 series in the original post.
For those of us who sent payment without that specification, how can we fix that to speed up the process ? or at this point, just wait for you to figure it out ?
:cheers:
:cheers:
Thanks for pointing that out!
I'm OK with the people who have ordered 80s kits not stating "80s" for now...I was just trying to set some presidents on the ordering process. I'll update post #1 to reflect that.
Ordered Kit #3 and had a slight issue with the adaptors for the 2nd row dome and cargo area. One of the leg wires came out, but its an easy fix after talking to Pfran. The end caps pull off easy. So what I did was pull the caps off, strip a little more wire off, put the caps back on and touch a little solder to them. No more problems and the wires are secure. Just a tip if anyone has the same problem.
The lights work great and are very bright. Thanks Pfran!
Thank you for putting this together, i believe I completed the order information correctly but as I see in one of your recent posts that some made a mistake would it be possible for you to update with a list of those you have the correct info for and am able to ship to?
Cheers peter ( Bogart)
Good idea Bogart. I ordered/paid on the 24th and even though I got a payment confirmation directly from paypal, I haven't received confirmation that I'm on the shipping list. I'm pretty sure I gave all the necessary info, but I could have a mistake somewhere and my order is in limbo without me knowing about it.
I believe Paul puts the kits together on weekends as he works full time... you'll receive a tracking number via email... and with this being a holiday weekend it could be a few days
Lou
Could someone post up or explain the install process? I am interested but need to know how to install these as I am not the most handy person. Thanks
80 Series LED kit - Install Instructions
1. Pull your 10 amp dome light fuse.
2. Remove the light covers for the map light, middle dome light, rear dome light (if so equipped), and door courtesy lights (if so equipped)
3. Wait 4 minutes for the OEM bulbs to cool down.
4. Remove the bulbs for the map light, middle dome light, rear dome light (if so equipped) and door courtesy lights.
5. Insert your spring festoon adapters into the middle and rear (if so equipped) dome sockets. (Don't connect your LED panels to these spring adapters yet)
6. Insert your map light 9mm bulb adapter into the map light socket. (Don't connect your LED panels to the 9mm adapter yet).
7. Put the 10 amp dome light fuse back in the fuse panel
8. Turn on the map light
9. Turn on you middle dome light and rear dome light (if so equipped)
10. Open all 4 doors
11. Gently plug in your 48 LED panel to the map light adapter. If the light turns on then firmly attach the connection. If the map light does not turn on, flip the LED panel side connector (not the inserted adapter or the inserted adapter connection side) clockwise 180 degrees, verify that you have a working light and firmly attach the connection.
12 . Peel the back adhesive covering paper/plastic (the side opposite of the 48 LED bulbs) off of the 48 LED panel and attach the 48 LED panel to the inside of the lamp housing.
13. Replace the light cover for the map light or dome light depending on which stage of the install you are undertaking.
14. Turn off the map light or dome light depending on which stage of the install you are undertaking.
15. Repeat the process in steps 11-14 for the middle and rear (if so equipped) dome lights.
16. Gently start Inserting a 10 LED door light into door socket. If it lights up then firmly plug in the connection. If it does not light up, pull the 10 LED bulb out of the socket and rotate it clockwise 180 degrees. Verify that you have a working door light and firmly secure the connection.
17. Replace the door courtesy light cover.
18, Repeat steps 16-17 for the remaining three doors.
19. Close all 4 doors
Same here, order went through on paypal on the 23rd. Just curious if they shipped....
Jason YY said:
I sent a paypal payment as well, didn't realize that my shipping info was not included when sending the payment.
I have followed up with a PM here on Mudd- looking forward to getting these installed.
Jason YY
Labels tonight! Been out of town. Will update this thread later after I get all the labels printed.
I got a few PMs stating that some 48 LED panels were arriving to customers with 3 bulbs DOA. I reported this to my supplier and they halted shipment of an order so that they could conduct QA. Sorry about the delay. Everything is in the mail tomorrow morning.
UPDATE #2....
Shipped to:
J O Cantu
drohweder
cruisermoose jr
ucbezerkeley
m Birmingham
jasonzx
ncduckman
jasonYY
Huntir
retodd
bogart
yah.h00ey
darasick
cme4lyt
msneedtx
nellie
sasquatch
J Hendrickson
shredwagon
I will go through old PMs tomorrow and address any service/hardware issues.
Status
