I have a 1996 80 series, 115k miles, lockers. I bought the truck a few months ago and added a OME 2.5'' lift kit with caster correction kit & 1'' Manofre Spacer in front. I had a shop install the lift. immediately after lift install I was getting the GRRRR sound while accelerating/decelerating. After inspection of rear driveshaft it was hydrolocked full of grease and phase was not correct. It cured 95% of the noise but am still having some noise around 65-80mph. While under the truck diagnosing the problem I felt my Transfer Case which was really hot, to hot to leave my hand on it. Last week I have the front-rear Driveshaft Ujoint replaced because it felt hot to the touch also. Even after replacing the Ujoint it still feels hot to the touch along with my transfer case. Also had transfer case & diff fluid changed.
I drove this stock truck from FL to NC with zero issues. Immediately following lift install i had the GRR noise during acceleration/deceleration. I took out front driveshaft and truck still had noise.
Do these transfer cases run hot from the factory?
Thanks, any info will be appreciated
