That’s some hard earned money
Being able to buy a Pig by the pound at that rate would sure make it easier to come in under the $5000 budget target!
Yep, don’t want to get your hands too close to where they are working. They really do work well together, almost like they’re twins!Damn! Fast work, now drop the saws all.![]()
Whoa!One less Pigeeeeee we cut it up it is going to the scrap yard , keeping the axles . I will cut the gas tank open and take pics , We need to finally see how the fuel lines work !!!!!!!
Savages!!!Animals!
Do we need to start having meetings now??Oh forgot, Knorr brothers had a pig intervention for me on Friday, I am 2 days clean!
This is great, 'cept I am trying to picture where the fuel suction line begins on the floor of the tank?1976 FJ55 Gas tank Nipples All on top of tank , The red is fuel intake , all the gray lines are vent lines in all corners . Also the fuel return line is just that short Nipple by the red intake ,
Somebody might want to save this ????
I think so, if the Pig is not level, or fuel is sloshing around there will be times when a vent line might be submerged in liquid and unable to relieve pressure or vacuum. It looks like a good design.Question for the group... Is it all that important to have four vent lines or would two be enough? Do you need to vent at all the corners?
I don't think the 4 vents does any harm! Just a few more lines to join up before going fwd to the charcoal can.When I had the water tank built, the builder welded the baffles in all across the top of the tank and had holes at the bottom. That trapped air up into all three compartments and wouldn't let me fill it up completely with water. I had to vent each compartment and wasn't sure about the baffling in the stock tank. I have the 55 gal. aftermarket tank and it has four vents coming out of it.
This ^^^I assume that's to cover camber to either side with or w/o uphill or downhill slope. Hard to imagine though that you would find yourself in that situation for an extended enough period to actually pull a vacuum on the tank while under operation. I'm also assuming you need to keep it vented to both fill the tank and to also pull fuel out of the tank with the fuel pump while in operation?
I am not totally following you Evan. Are you saying you were able to drill this hole and then unclog the fuel supply line?pick up , bottom of the same tank i had to drill out when it got clogged , for reference .
If you see that ( baffle ) pick up is on the bottom of it , all other lines are on top of Baffle .hard to see but i cut tank right where that pick up is . ( I just cut and opps wrong spot to cut )This is great, 'cept I am trying to picture where the fuel suction line begins on the floor of the tank?
Did y'all cut part of the bottom off?
How does the fuel supply line transition from bottom to top of tank?
Thanks!
Yes the hold drilled in the bottom of the tank was to drill out the pick up tube where it was spot welded to the floor of the tank . used a long drill bit , and then a flexible cable ( think speedo cable ) back through to the top . only the first 2 inches were plugged upI am not totally following you Evan. Are you saying you were able to drill this hole and then unclog the fuel supply line?
How did you locate the intake from outside the tank?
Thanks!
On a '71 the vents go to two emission tanks, one behind each cargo panel which then go to one line up to the charcoal canister. I eliminated the pass. side emissions tank and run all four lines to the driver's side emissions tank. I also have a GM fuel pump with a vent coming out of the top of the tank which ties into the line going up front to the charcoal tank. Spaghetti!I don't think the 4 vents does any harm! Just a few more lines to join up before going fwd to the charcoal can.
