66' FJ45LPB Parts Needed
cruiseroutfit
Supporting Vendor
Moderator
Utah
Website
cruiseroutfitters.com
I'm in need of a pile of parts for my wifes LWB 45 build: The Old Lady's 66' FJ45 Build
Bump for my current needs:
Parts I Need: Let me know if you know of a source!
Factory headache rack
Bugcatcher Window Weatherstripping
Rear Tailight assemblies (45 LPB) (mine are working but would like some cleaner options) - Still need
Rear tailight plugs for vehicle side of harness (this one has been hacked) - still need
Fuse Block Cover
Temperature control valve (mounts on F head)
Early horn relay (58-69 era) (have aftermarket but would like a working OEM with the clear plastic cover)
Dimmer Switch (mine is working so-so but would like some cleaner options)
Early 4WD indicator switch ('58-'67 era)
Hardtop roof hook ('58-'67 era) (think I got a couple of these from Eddy @ Proffitts)
Inspection Light socket (firewall mount with studs instead of spade connectors)
License plate bracket like this one: 66' FJ45LPB Parts Needed
Back hardtop glass
Passenger Side Bench Seat Bottom
Wiper motor(s), one of mine has failed completely, both are rough
Steering wheel, mine is rough
Sourced :cool:
OE Carb (has Rochester but runs) - No longer need. Thanks Mark A.!
Hub caps (have later model ones I will likely use, but I'de like a full set of the period correct ones) - Set on order from Ehsan :eek:
Front Bumper
Spare tire mount assembly
PTO Winch (where are they when I actually want one :D ) - One en route
Tailgate (LPB)
Spare Tire frame side hanger bracket (found a part on the actual tire carrier)
Repro Engine, Heater, etc stickers - Thanks Shane!
I'd love to get some of these parts coming to Cruise Moab 2009 :D Let me know!
Updated: 12/01/15
This looks just like the list you posted when you GOT the truck. I thought you had most of this handled already.
I am sure we'll talk before I come to CM08. I will most likely be in the 40 again, so I don't think I'll be moving any headache racks for you!:p I will help with whatever else I can.:)
I've chatted with some folks about some of the parts ;) but we havn't firmed up anything yet. Expect a call in the next day or two :D
I can look when I'm cruising wreckers in Honduras this weekend. Do you need the entire rear tail lights or would the base be a start? Here the light lenses are often smashed but the base may still be there.
The bases would be a great start, my lenses are cracked but usable, but someone hacked the back out of the bases to put in some generic lightbulb sockets :eek:
Thanks!
Kurt I thought I sent you a PM of person who made the repos of the bug catcher weather striping. Did he not have any left or you couldn't contact him? I still might have is phone if you want me to contact him.
Engine emblems might be made by Shane in Oregon City. If not contact Cruser_Nerd, that's who help me get mine.
If you do score some other rear tail light housings I could us the plastic piece that lets the light thru for the license plate.
John
Kurt, Stout taillights are the same, found some in a wrecking yard, but sold 'em already. I might have the body side plugs tho, also may have some nos weather stripping from SOR, bought in the late 80's not sure I want to part with my last carb
Paul
Headache rack is a possiblilty too.
Found a headache rack AND the light bases. The problem was the yard owner who sets prices was not there so we could not get anything.
Kurt,
We make reproduction headache racks if you are interested. They are a little more stout than the factory but look the same. The factory ones were made out of channel where ours are square tubing. We even bought a special bender die just to get the exact radius of the original headache rack.
You know where to find me if you are interested.
John
Kurt,
John
Post some pics, I would be interested in one.
