60 series....Tech and Classifieds
Well done!
I put the same gauges in the buggy (plus a small oil temp one next to the trans temp). Speedhut makes some good s***.
Looks like you've got a voltage/charging problem though.
Yep. It’s a GenIV thing. Same thing happened on my truck. Need to change voltage regulators on this one.
LED Headlights for Land Cruiser FJ60 - Set of 2
You can't use just any LED light. Reverse polarity module is mandatory for FJ60.
Any plans on offering a heated version like the TruckLites? Living where I live, I am afraid to run the LED version during the winter seeing as the ice would pile up on them at night. Would rather have you support my habit/addiction than anyone else.
Or convert the alternator to 1 wire with a voltage set point of 14.2 or 14.4. That’s my plan. The 13.6 default with the resistor isn’t enough for my Audio renovation.
Follow up post from my A/C questions. Took my 60 to a shop today and had the Freon exchanged. Looks like I have a very minor leak on one hose. Hopefully the new Freon will atleast last until cooler weather. Planning on doing a full A/C replacement this winter.
4:11 3rd member swap underway.
I have some parts for sale. Can hold them and find you at SCC if you'd like.
4Plus Ubolt Flip Kits for FJ60/62 Land Cruisers (4PlusProducts | FJ60 | Suspension Parts | U-Bolt Flip Kits). Used for 4 years. I have both the front and rear kits. $150 shipped for the front kit. $150 shipped for the rear kit.
full
full
Bilstein shocks (Bilstein B8 5125 Series Shocks 33-230320 , Bilstein B8 5125 Series Shocks 33-230337). Fits FJ60/62 Land Cruisers with around 3" of lift. Rides way softer than OME or Ironman shocks, but too soft for trucks with a lot of extra weight. They rode great in a straight line, but allowed too much body roll for my liking, and not enough valving for extra weight. $100 for the front pair. $100 for the rear pair. Shipping will be extra.
full
full
Marlin Crawler Front Shackle Kit. Being a front kit, it has longer bolts and the needed spacers. Needs new bushings. 4.5" hole to hole. $50 shipped. These are for a mini truck, but will work with 60 series as they share the 18mm bushing ID size.
full
Marlin Crawler Rear Shackle Kit (Shackle Kits | Marlin Crawler, Inc.). Rear 89-95 5". Practically brand new. Ran on my FJ60 for 500 miles or so. Bushings are still brand new (never used them). $75 shipped.
full
Advance Adapters Chevy 350 universal motor mount kit. Could use new bushings and some welds ground off. Perfect for a budget engine swap project, or for mockup purposes. $30 shipped.
full
I didn’t know this one was still in the area. Was sold at Billy Wall’s car lot on Hwy 471 years ago. The interior is interesting to say the least. Definitely different with wood door panels and a big turtle carved into the center console lid or the odd seat material. Truck was clean and low miles. To each their own I guess.
Land cruiser FJ60 1983
This looks interesting...if you want to roadtrip back from Portland, OR.
$14.3K
1989 Toyota Land Cruiser HJ61 RHD JDM Turbo Diesel Landcruiser 4x4 *
The 1989 fully loaded VX home-market model includes:
- 24v electrical system
- High roof with glass power moonroof (works, no leaks)
- All power options including antenna and mirrors
- Air conditioning (blows cold)
- Recaro "turbo" cloth velour seats
- Rear window wiper with delay
- Original rust-proofed frame
- Factory tinted windows
and more...
The Good:
- 4 speed auto trans with steep overdrive
- Push-button high range 4WD (manual low range)
- Manual locking front hubs
- Toyota PTO firetruck grade winch on frame extension
- 4 taper bearing full floating rear-end with limited slip diff
- Rebuilt radiator with low silicate coolant and heavy-duty nitrate pretreatment
- Rust-free frame and undercarriage
- No cracks in dash
- No pets, smokers or salt
- Clean OR title and regular OR plates with current tags thru 8/2018.
The Bad:
- Some power windows don't work but drivers window and sun/moonroof DO work
- Tires due (ready for your choice of wheels and/or tires)
The Ugly (asking price reflects "as-is" condition, see pics):
- Front bumper bent (NO wreck, just minor fender-bender, negotiable on fix depending on buyers desired bumper)
- Fading clear-coat paint on hood and other spots
- Missing left front bumper end
- Typical drivers seat edge wear (see pics)
Mike at @Cruiser Corps has that same truck but in left hand drive that’s the real Narcos deal. If something happened to my 60 I’d be rolling up on him with a wad of bills to have it.
Yeah that looks almost identical to mine other than the steering wheel on the right side!
I actually sold mine the other day to a local customer if ours.
I have already tried to buy it back and it’s still in my possession!
What did I do?????!!!!!!
I might have to go get this to fill the gap.
