Planning to pull and overhaul the distributor on my 87 fj60. I've already replaced the cap and rotor. I have the packing/dust seal oring and the lower o-ring on order. Mcgeorge toyota shows the signal generator 19250, the advancer 19220, and the pole piece assembly aka rotor 19181 all as available. I'll try and order them and see if they are really still available. Is there a source for the springs? What other parts should I be concerned with replacing? If I find the lower gear has wear is there a replacement? @4Cruisers, @FJ40Jim @OGBeno
