40 series general tech and classifieds
I re-used my old nuts & bolts. You may have to soak them for a bit, but you should be alright. No idea on the sizes.
an FSM is always a good idea - I have a PDF for the 2F engine that I can e-mail to you; PM me your e-mail address
I reused the bolts when we replaced the header - I even reused the half-washers :hillbilly:
Pm'ed you for a copy:)
I'd like a copy too if you don't mind, sent a PM.
Memcruiser i have a whole set of gold-cad plated bolts with plenty of extras. When u find out what size you need for the manifold I would be glad to send you some if I have the right size.
Sent from my iPhone using IH8MUD
I'm trying to change starter this morning. It takes 17mm wrench. None of my wrenches or sockets fit to where I can actually back out bolt! What's the trick other than taking it to mechanic? I guess I could buy a 17 and cut end off to give me room.
Starter will still turn over with a boost only.
From memory, you probably need a short (as opposed to deep) 17 mm socket and a wobble extension. I don't think you should have to cut a socket or resort to a mechanic.
Were you able to get a "free" starter under the SHUSH warranty?
Could not find the receipt. Not sure how to get a wobble extension on it. Have to try harder.
Have 4 of my kids cousins coming in town to go off roading and boating.
Land Cruiser and boat are both broke! LOL.!
I feel your pain. Nothing ever breaks down at a convenient time. :mad:
Wobble extensions, cheap at HF.
9 Piece 1/4", 3/8" and 1/2" Drive Wobble Socket Extensions
Starter is fine. Changed batt ground and all terminals. Then noticed this wire kind of looked bad. Pulled on it and came right apart.
It attaches to this which than goes to starter solenoid, what's best way to reattach ?
Well nothing is working. I cant get the black plastic connector internals out to rewire so I am unable to
energize solenoid. Tried buying generic connector at auto parts store just to see if I could power solenoid but no luck. What to do now. It is about to go to mechanic. Starting to lose patience.
Maybe have your wife take the plug to Radio Shack or Autozone and ask them to pull the connector out pretty please or see if they have one that'll work?
Nice!
What is the grounding wire that goes from starter to frame called. Mine was kind of bad looking and
bought one at a part store and bolt wont go through eyelet or hole, whatever the MFer is called.
I guess I need to order one.
