If you go to a header, you will have another set of issues in that most (all that I have seen) headers have a thinner flange than the aluminum intake. I have tried cut washers/shims/double gaskets, remflex gasket, single gasket doubled on the exhaust port...I haven't found a long term solution yet.
If you have the factory PTO....only the two piece shorty header will work...unless you want to section and rotate the collector...then if you do a shackle reversal, upper shackle bolt wants to be exactly where the collector sits....
Don't ask how I know all this....
I was hoping to unbolt put new gasket in and re-bolt. I was going to ask the question if it could be that easy or do I need to get all new hardware.
I think Nolen was right. Should of bought the 30k truck!
