Anybody got ideas pls call 901-290-0880. I'm out in country with 2 kids on a tour.
Tried to call but operator said the call cant be completed as dialed. Number right?
wanabecruisen said:Tried to call but operator said the call cant be completed as dialed. Number right?
I would let the local guy build it. Love Georg. His work and the cleanliness of his work it unparallelled. That said, if you have issues your local guy built it, he will make it right.
I know that Bobby guy is legit.
I might do this. Local help is nice to have.
Cage should be tied into frame>>> still gotta do mine![]()
wngrog said:Do you still have that old 2 person cage?
MEMCruiser said:I am not sure why 12.6 volts wont turn over starter but it didn't. The tow truck boosted me right off.
If a starter is going bad can it require more battery volts then normal?
I am parking it and going to the lake. Thanks for the help.
I believe your 62 have the same starter, but it might just be the 60s. If it is the same, swap them and see if you still have problems. It is very simple to do.
Got a PM to georg. nothing yet.
he is on vacation
AndyO78FJ40 said:I'm pretty sure Shush recently installed that gear reduction starter, but it could still be a bad ballast. The wire going from the battery to starter could also be bad so the full 12 volts don't get to the starter and therefore the ballast doesn't allow the starter to turn over. You could try replacing the wire. Has the battery been load tested? When you were stranded before does the starter normally try to turn over or is this typical. I believe your 62 have the same starter, but it might just be the 60s. If it is the same, swap them and see if you still have problems. It is very simple to do.
