You are always welcome, Lee.
And also good tech.
The Sleepless in Seattle FJ40 deal.
And also good tech.
I'll give you $6,000.
Tcase may be pumping into transmission unless you see lots leaking. 1Q of 90wt looks like 200 gallons on the ground.
There is a kit to "fix" pump issue from tcase to tranny.
short term fix is a hose between the fill plugs that allows the overfilled to drain back to the underfilled. You can have one made at a hose shop like Parker for around $22.
The other big area for a tcase to leak is past the seal on the output within the speedo housing. It will leak into the parking brake drum.
If you're considering an Orion, get the hose mentioned above for a short term work-around.
Is the low gearing in a 40 t-case higher/lower/same as a 60s split case?
There is not a Bobby that works here at Cruiser Corps. There is Mike, Jeff, Dylan, Ariel and Josh.
Mike, here's the kit Lash and Nolen mentioned. You can build one yourself, but the MAF kit is an easy fix if you don't have time to source parts and fab your own.
Oil Return Kit (Transmission to Transfer Case)
You know I'd already have been there if personal issues hadn't taken over. I'm in dire need of some Mississippi porch sittin' therapy. Hopefully that'll be happening soon.
Mike I might have the hose you need. I'll look.
This just keeps getting better.
Mike to be honest Bossman's 80 was the truck you should have bought.
Bodean said:Jrob needs those doors for Srobs rig!
What would you guys pay for this truck? It's for sale in Waco, 100 miles north of me. One of my neighbors is negotiating with the seller, who's stuck on $10K.
Rebuilt engine, new clutch and rebuilt brakes, new tires, new upholstery.
Heater is missing, Holley carb, no PS, pretty much bone stock from what I can tell.
Without seeing it in person, I'm thinking $8-9K, not 10.
Toyota : Land Cruiser FJ40 | eBay
I think if he thinks it is worth 10 and you say 9, offer him 9500.
