This could probably go in it's own thread, but there doesn't seem to be a lot of people putting 1FZs in 4x vehicles yet. IPOR and Gary Wagoneer, of course and I don't know what they did for gauges.
Hopefully, if someone is doing this conversion they check out this thread or hopefully it comes up in a search.
I'm really happy about how this came out. 80 series gauges are all driven by the ECM. 40/5 series, of course, are all run off of sending units. The 80 speedo is pulse driven. It would be great to put the 80 dash right up to the plugs in the harness, but it would never fit without cutting the hell out of the dash.
The circuit board on the back of the 80 cluster sends power from the four plugs to the gauges through the screws that hold the gauges to the circuit board. I figured I could put eyelets on the wires and just run the directly to the screws. The circuit board tells you which screws are for what.
The gauges happen to be in the same order as the 40/5 cluster, but are sideways. Fuel is to the left of volts and oil to the left of temp. The gauges are deeper than the stock ones so I needed to make something to move the gauges back and mount them solid. It needed to be plastic so the screws could go through and stay insulated. If you spent more time you could probably get them straighter, but they only fit so well in the stock metal part. If you built a whole new part to replace the metal part you could make them fit better.
Fortunately, the school I work for just bought a 3D printer that prints in ABS. I teach CAD as well as Auto, so I needed to be able to use the machine so I can incorporate it into the curriculum next year. I drew the spacer in Google Sketchup because its easier to use than AutoCAD for solid modeling and I don't have Inventor on my laptop yet. The part took about 8 hours to print.
I drilled though the holes in the metal gauge cluster that once held the gauge mounts into the spacer and secured it with small screws. I had to cut a bit of the metal away to fit the speedo circuit board. I choose not to drill a hole in the cluster face for the tripometer reset knob so that just wont work. I also took the plastic off the speedo behind the face and replaced it with the original backing plate so it would not have gaps around the edges.
To find where the holes needed to go I borrowed some enamel paint from the wife. She had some nail polish that worked great. Dabbed it on the studs and pressed it into the plastic. When I took the gauge away it left dots for me to drill. The bolts were too short so I used some 4mm screws from my RC car stash.
The light bulbs and high beam indicator will still be useable.
I have more pics, but they are taking forever to get downloaded from my phone.
