- Thread starter
- #61
Thanks Mat, yup... been busy. The chassis might win something, but the body will still be beat/ rusty. But as we all know, it's all about the mechanics, the body is superficial.
Next three, might be handy for anyone thinking of a body lift. Got more done, front third is in, cleaned up the knuckles and found out I threw away the twisty metal ring (twisty ring, felt, rubber) and the two piece retainers to hold the whole kit and kaboodle on.
Ultra heavydidn't even know there was such a thing, thanks for the heads up.
Phil,
Looking great. I'm really enjoying watching your build-up.
Just some info from my personal experience... The rear Dakars you have look like the ultra-heavy ones and unless you plan on a couple hundred pounds in the rear full-time, you might want to pull a leaf out so soften up the ride a bit. You also might have a pretty good stinkbug look if you keep all the leafs in.
Anyway, keep up the good work.![]()
Ok, my terminology might be slightly off, but it is the spring pack with the most leaves that OME offers. I put about 200 lbs in the back and the spring didn't even begin to flex. Once I removed a leaf, the rear sat a little lower (still have a slight stinkbug) but the ride softened up a bit especially with a load.
Hope this helps a little.
Okay in all my years of having and working on my 62 and all my time on Mud, this is only the second time I've heard the "stinkbug look" mentioned. Can someone please explain this to me?
Also found that I needed an AAL in the front spring pack too. Original OME's were too soft.
Tony
