If you’re willing to drop the $ this is the way to go with the 1.5” bracket (if you have an aftermarket front bumper).
KDSS MAX Relocation Kit With LCA Skid Plates -Stock and Aftermarket Bu
The Anderson Overland Land Cruiser 200 Series Full Front KDSS MAX relocation full kit for high Clearance bumpers. The Only KDSS Relocation kit that moves the KDSS sway bar forward to the maximum allowable position and positions the lower KDSS end link outside of the LCA cradle while retaining...andersonoverlandoutfitters.com
the standard 1” kits from Slee or trail tailor work but unless you relocate your end links outside the cradle they will tweak the bushings pretty hard. I did not run with the 1” kit
If you use the 1” you can do the sway bar end link relo yourself for under $100, it just takes some effort to source the bits.
If you decide you want to do the 1” kit I have my old one from trail tailor and would be happy to sell it cheap.
LOL - you seem to be the pioneer for much of my plans. I've got the Anderson relo kit but I have the 1" and not the 1.5" - you think that'll be a problem?
