- Thread starter
- #21
Great info i really appreciate it, Nd now that you mention it, for the 37's did you regear yor 80? And if so i am planning to go to 5.29 sinze i want some 37's but if i get a deal i will be getting 40's hahaHey, you are gonna get every bit of advice from stay with stock..... big tires are over rated to..... go 44s & cut as needed.... the biggest bang for the buck right now for dual rate coils that can take the longer 28" shocks is a 2.5" Tapered coils by Dobinson. $325 a pair. Get the 6" fronts shocks (1.5" BS) & 4" (2"BS) rear shocks $125 per. Another great shock that takes less bump stop spacing than the Dobinson shocks is the Icon 56511 (.5"BS) & 56512 (1.25"BS) $159 per
I have coils that are very similar dual rate coils to the Dobinson Tapered called Slinky but they cost a lot more... very good coils but spendy.
By the way I run 3" suspension with 37s stock drive lines, stock control arms, stock pan hards, stock brake lines.... I do have a body lift without issues just have to readjust shifter linkage. Body lift is not need to run 37s... heck nowdays they run 40s on a 3" lift... but ya gotta cut dim fenders out.
Here are some links
Compiled 80 series suspension component spec thread... shocks, coils & more.
, but what are the current thoughts on the longevity of 37s with a relatively stock drivetrain...no chromoly shafts, etc.
