Yeah I've been looking for what factory consider normal operating temp range. I do suspect we've variation in the years and milage of engine. But I'm sure hitting 197F or higher in normal driving, is indication of system issues that needs correcting. 06-07 I've biggest question on as to what is "normal" from factory. But I do have logs indicating that 187F (high I hit) is baseline in the 06-07. That with full metal skids and belly pan, the temps jump up to ~192F average (w/o heavy bumpers). That was Merlot 07LC w/63K miles. In it, I did hit in the 201F when I ran it up (high RPM run) w/bellypan, trying to heat CATS. So was not a good ECT test. It also was without doing a full coolant system service. But just driving around with the full metal skids and belly pan, it did run hotter.
Lately I've been looking more 98-02. Which I see consistently 184 to 187 F in well turned engine. The two I'm looking at currently, are high mileage. With high mileage comes wear. So they are looser running engine presumable. I suppose that would likely mean less friction and as such low temps may by a few degrees.
Today I'll be running short term logs on a heavy 05LC, no bell pan or #1 or #2 skids on. I just serviced coolant system. Engine seem okay no apparent vacuum leaks, with report newer spark plugs. Does have some unusually wiring. One wire is tap into #1 coil??. Some fuel injector wires have been spliced. Seem to run okay. It's actually a Tundra long block in it, of unknown year and mileage. I did find it had non OEM thermostat and rad cap. It was running cool ( no boiling issues) ~187F. I'll report back on its temps.
