It should probably be pointed out that a larger tire technically requires less backspace to keep your scrub radius as-stock. I’m not sure how much you need to move things to keep this in check. A large scrub radius change can make for all kinds of bad behaviors.. I’ll let you do the research.
That said.. I’ve personally never been a fan of spacers despite other people’s success with them. Double the lugs/studs to have problems with, hardware that might not be as strong as stock, etc. Fortunately I don’t need to run them, with my Rock Warriors putting the tire/wheel exactly where I want them, so I guess I’m lucky. And if it didn’t, I’d be looking at different wheels with the correct offset or maybe a tundra arm swap.
