- Thread starter
- #161
Ok so I ****ed up...
The oil feed port for the turbo on the block was blocked..
I pushed some mig wire through the blockage, then used larger and larger tig wires. It was a few inches back. when I checked for it to be clear earlier I had only checked 2 inches. The blockage was about 4in deep.
There was lots of concern about other ports to the internal mains or other places that might not get oil.
Brian was here helping.
We started the motor a couple if times and git good flow, to flush the port out.
Then swapped in another stock ct26. Then hoped the motor would not die in the next few days.
I do remember clearing oil passages during the build and blowing air in a d spinning the crank to get air at each crank journal.
start up and sounds great still.
Oil pressure rises to 63psi and falls to 20 when warm.
So the thought is that the nut came off because of the no oil when the turbine would stop abruptly and the nut would then spin off.
