Well, I'm
still trying to finish my transmission install. The good news is that the clutch alignment tool from Specter Off Road worked great. Part Number 200-11HZ has the correct spline count (21-spline) and the correct pilot bearing diameter (15mm), so the clutch aligned perfectly.
However, the bad news is that the flywheel bolts and clutch pilot bearing are the wrong size, and the flywheel alignment pins were not included.
Full story - The stock clutch and flywheel for my truck is 275mm. I read on Mud that many people retrofit the oversized 1HD-T 300mm clutch/flywheel for better clamping load and a heavier flywheel. Especially if they plan to turbo. Great! I love upgraded stock parts.
I did a little research on Mud and realized that Kurt at Cruiser Outfitters stock(ed) the 300mm kit. Gave them a call and ordered the kit. Unfortunately, Cruiser Outfitters did not have the clutch cover for the kit. They asked me if I would like to source the clutch cover myself and ship the kit immediately, or wait until they received a clutch cover and ship the kit as a whole? I opted to ship the kit immediately and source the clutch cover myself. No problem. Found clutch cover from another vendor and arrived without incident.
Fast forward to install. Realized that the clutch install tool Cruiser Outfitters supplies is incorrect. No worries, they're hard to source and mistakes happen. Received correct tool from SOR. Go to install clutch cover and realize 275mm setup uses six M8 bolts to fasten the clutch cover to the flywheel, but 300mm setup uses eight M10 bolts. No flywheel bolts were included with my kit. Dangit. Oh well, I'll install the bellhousing, throwout bearing, and clutch fork...except throwout bearing supplied in the kit is 35mm for B series, but I need the 38mm for 1HZ. Double-dangit!
Obviously mistakes happen and this is a very niche truck/kit. I'm confident Cruiser Outfitters will take care of me. Just wish I was making more headway on the install. FWIW, the parts supplied by Kurt and his team are very high quality - OEM Toyota, Aisin, and Exedy components.
Rant over. I'm going to work on rust remediation and diff gear oil change. Wish me luck!
