well that sucks but look on the bright side, time to buy a tool
4 in. x 36 in. Belt/6 in. Disc Sander
you're welcome!
you're welcome!
you're welcome!
Haha- I actually went an bought that exact POS when I was rushing to get the engine in over the holidays, I go to unpack it from the box and the cast steel chassis that it rides on was cracked in half.
How is your clearance between the AC tensioner bracket and tubular crossmember? I ask because your mount posts look quite a bit lower than mine yet I only have 3/4" between the bracket and cross bar.
I was able to thread the stock toyo temp sender threads nicely into the LS head - no adapters necessary. From reading other swap threads, some people did need adapters, so not exactly sure how I got so lucky.
It threaded in because it isn't the correct sender. On the 1FZ there are two.. one for the toyota ECU (what you used), and a single-wire sender behind the distributor/water neck that sends a signal to the water temp gauge. The second one is what we've been having to machine and rethread to fit the port on the LS head.
I don't know whether you can hook the gauge up to the sender you are using, but I'd doubt it.
Easy mistake to make.
