Build 1989 Toyota Land Cruiser FJ62 Build
What did you use to remove the fuzzy insulation on the interior floorpans? What soapy stuff did you use at the engine bay? Any electrical issues when you sprayed it off?
Thank you!
This is similar to the method I used as an aircraft mechanic in the marines, but it's important to put the label INSIDE the bag.
Definitely comes in hand there inside the bag as you said the ones I put outside are already fading off. Little details matter!
Thank you!
I just removed it with my hands to be honest
It came right off when I ripped it off, but you can also use goo gone if it’s stuck
Thank you!
I used engine degreaser on the first run, on a hot day, and then a really hot water bucket, after that, I phoned it with degreaser liquid inside my pressure washer, and then sprayed it off multiple times
After that, I used the gel type rust remover, the regular spray does not remove it because it dries off and gel type sticks on all night and then in the morning all the rust has gone
I have no idea if there is electrical issues or not but if you’re going to do it on a running car, I would wait until it’s fully dry. Maybe give it four hours and a hot day with the engine bay open
I also used a air blast canon from ADAMS
Holy smokes! That air cannon is nice! I appreciate the details on the cleaning, will be one of my many projects. Currently adding peel and stick insulation to the inside of the door panels and adding boeshield to the window tracks. It's a process!
Thank you!
Thank you!
Taking off all this rusty stuff / cleaning it reviving it is a process for sure I’ll add some more cool stuff tomorrow
This was a nightmare, but obviously my suspension has been rusted through since 2005
But I finally figured out how to take it out in a really easy and effective way if anybody ever gets stuck just let me know. I’ll send you some videos.
ICON Master Interchangeable Puller Set - Item 58118
https://hftools.com/app58118
