1983 40 Back to Life
Such a cool project! Looks like most of your smog is there if not all of it, but there could be some VSVs and other little switches etc missing. Smog pump can be rebuilt at BZ in Canoga Park. PS goes on the driver's side above the smog pump (and tends to leak ATF from the front bushing). I would guess your radiator is original to the rig since the condenser seems to be all there and undisturbed.
You'll need a working cat and air rail etc to pass. Plus a carb rebuild - send to Mark A when you're ready for that. My DD is an 83 60 that passes smog in LA but not without significant help from Mud and @Spike Strip in particular! Can take some smog equip pix if helpful.
If your goals change and you want to flip it, a clean 3FE swap with a 5 speed in a 40 would be a unique (and pretty sweet) setup. But I also get the back to stock vibe, too. May also consider going back to the 4 speed if you are going to do the stock thing. The gear spacing and action in the H42 is just perfect imo, even if it's missing the OD gear.
If you could add a few pics of yours to this thread that'd be great!
Here’s one from the roll. I’ll add more when I’m back home later today. This is the ABV and a few associated switches. Note the Saginaw PS conversion :)
Ok - more photos.
General view of the control side of the smog stuff. Note ABV, EGR control, and various other controls. I am noticing that one of the vacuum hoses looks disconnected on that center nipple thing... I'll have to go back out there and check it!
Smog pump resides under the PS pump. This is the Saginaw conversion from Valley Hybrids @orangefj45, works great!
Air rail, VSV, and BVSVs. The two nipples (the purple thing at the bottom) attached to the BVSV have a nasty tendency to snap off when doing any work nearby.
Charcoal canister. This was a replacement from Amazon (maybe??) that works well, but this might look different in the 40. The little solenoid on the upper right opens and closes to let gases into the intake stream.
EGR. This can be pretty robust but you will want to check it. Pull vacuum on it when it's running and if the engine dies, it works.
Last one - EGR control, HAI flap and heat riser. The heat riser (that accordion type pipe running to the underside of the intake) needs to be in place to pass visual. Doesn't have to be factory but it needs to be there. There's a HAI controller in the air cleaner, that can die. Not a dealbreaker necessarily, but apparently it helps control air intake temps in cold weather.
Here’s some radiator measurements. Mines an 81 w/ factory A/C. 21” wide, fin section is 17” tall. My radiator cap isn’t stock, previously repaired poorly so I had a new cap put on it.
Super stoked on your project. The body is in fantastic shape (that’s what he said). Keep posting. And since it has a Darwin fish might I suggest the addition of a Flying Spaghetti Monster FSM fish?
Ok - more photos.
Thanx for posting the pics...this will give a general idea of where I can begin.
View attachment 4203439View attachment 4203440
I have the radiator out now...I did an overall measurement of 21.5x20.5. I did outside to outside.
I removed the radiator so that more things are visible. Would I be correct in assuming the power steering lines are not original to this 40 and someone had some made to go around to the other side for a 3F engine? If so, I'll remove those. I also removed both drive shafts. While I was under there it looks as if the 2wd/4wd shifter has some type of homemade bracket on it. Also, the crossmember looks like it was borrowed from something else. As much as I'd love to keep the 5 speed I just don't like how things are thrown together on this thing.
I'm also hoping that you guys can perhaps point out to me in these pictures of what to keep and what not to keep. Maybe you can circle things? I'm not sure how that works on this site.
I’d assume they are the same with those outside measurements. And thanks for all these pics. I’ve been working through putting mine back together and this is extremely helpful
Nice! You are doing something similar?
Wow, this takes me back to an overcast day in 1983 when I stopped by Fowler Toyota (I believe) in Norman Oklahoma while I was in High school. They had 1 FJ40 on the lot and it was this very color. I thought it was the coolest thing I’d ever seen. I told myself I couldn’t afford it back then and I’ve regretted not buying it for the last 43 years!
That 3FE install looked relatively clean. I'd clean it up real good, wrap the wire looms up again, reseal the engine and re-install.
Register out of state like a ton Californians do and just drive it.
