- Joined
- Jul 22, 2012
- Threads
- 639
- Messages
- 17,550
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
Make sure you account for spring center pin length if you’re going to add a spacer.
Never measure from the ground, measure from the lower centre lip of the rim straight up through the centre of the hub to the fender edge. This negates tyre pressures, sizing issues from manufacturers, etc.Swapping the springs seems like a plausible solution. The rear spring rates don’t seem to be even. I can’t see how the drivers side could be that much heavier, with the tire removed.
This is with a 3/8” spacer on the rear passenger.
Spring hangers angles :
View attachment 3264603View attachment 3264604View attachment 3264605
I tried swapping rear springs to cure the lean once.
Happy to help! Ok, if you have enough leaves nothing stops you then to take one out on the higher side to level it out. One does not want to take a leaf out of a thin pack for fear of breaking a leaf when carrying heavy weight over rough terrain.Measured from lower lip of rim thru the center of the hub:
I am running 22psi in both rear tires.
I added a leaf to each pack in the rear at the same time I added the 3/8” spacer. Helper spring just make it stiff. Shocking it know! The Dobinson heavy rides like the OME medium.
I was planning on removing the helper spring next round, or just biting the bullet and buying a new set of medium springs to see if I can get a better match set.
The Dobinson spring are not marked like the OME springs. (-,o,+).
@locklaw adding different spring rates to the rear seems like it would be back for driving characteristic?
Thank you for the help gentleman!
I don’t know what’s wrong with these, every 40 starts to lean left.Swapping the springs seems like a plausible solution. The rear spring rates don’t seem to be even. I can’t see how the drivers side could be that much heavier, with the tire removed.
Yes I have tried swapping the spring side to side with no change. Currently I have a heavy spring on the driver and medium springs with a 1/2'' of spacer on the passenger side.
Not sure if your attention to detail would allow it, but you could utilize different length shackles to try and correct ride height or get it closer. Wouldn't affect the ride as much as farting around with leaf spring rate. Yes, spring rate is slightly affected by shackle angle, but I suspect it wouldn't be noticeable.
You could actually end up with a much much better ride and equal ride height by going longer shackles, ditch the AAL & leveler block/spacer, and relocate the shackle hangers to maintain proper ride height & shackle angle.I made a longer shackle in my situation. It's not as noticeable as the lean was. It is currently a trail rig.
