- Joined
- Apr 21, 2005
- Threads
- 115
- Messages
- 26,086
I didn't mention your tops figuring you would post. Have to do something to draw you every once in a while.
I have a paki top, an OCD top and bows.
None of which will fit that 1962 tub.
Won't fit without some work but it can be done. Here is a link with a lot of info. https://forum.ih8mud.com/fj25-owners-group/45428-fj25-early-fj40-soft-top-project.html Plus a couple of pictures of a top made to fit later FJ40 factory bows setting on a FJ25. Add in what Jim has done plus some making hard tops work. Not easy but also not mission impossilbe to get a cover to keep the weather out.
Will you knock it off, Mr. smarty pants! I'm trying to talk him out of it!![]()
Guess what followed me home?
...now we need more pics...
What are the correct wheel / tire combo for 62 FJ40?
cjgoode said:Does it still have the rear centered axles. If that drive shaft is long enough you would likely have to drill out the flange holes. pre mid 69 would have 8mm holes, where your 73 drive shaft would have 10mm holes. I drilled mine out to 10mm as the PO had 71 engine, trans and drive shafts. He had 8mm holds going through the 10mm holes, so I do not think it was ever driven after the engine swap, but a guess, the guy I bought it from never did anything to it other then store it.
