bolt size...please
You mean those 4 mm bolts with 10 mm heads and the 1.25 (I think?) pitch?
Hex head, 6mm diameter x 1.0 pitch
Likely 12mm or 16mm in length (can't say for sure as I am at work). They do have captive washers.
Biscuit is correct. They're 6mm with 1.0 pitch. I would use the 17 mm length, or even 27 mm to get down throught the gasket more easily.
6mm bolt
11mm head (Toyota) aftermarket will be 12mm
1.0 Tp
Captive wave lock washer and 16mm Flat washer
25mm long is OEM
The OEM bolts on my 71 definitely had 10 mm heads. (With a 4 with a circle around it stamped on the head). :D
thanks all for the info...best place to purchase these dudes?...i am gonna check at the local ace hardware...hopefully they will have em...of all the bolt/fastner threads i searched nowhere could i find this specific fastner identified....again thanks
osagecruiser
taking the top off this weekend to install our metaltech cage...want to put in new bolts while i am at it....
I got mine at ace hardware. I agree that you need to get the longer ones as they have plenty of room under the tub rim.
I don't "Think" they have a 10mm head, Ever????
Did you measure??
I DID :flipoff2:
#1 will not fit in a 10mm hole.
#2 16mm washer
#3 25mm long
Yes I have seen a 4 stamped in alot of Toyotas bolts, I dont know why that is??????
OK! I'm getting out the big guns when I get home! I use 10 mm Socket ALL THE TIME! :D
AATLAS1X said:
6mm bolt
1.0 Tp
25mm long is OEM
Dave's right, and it's a 10mm wrench. JIS or Japanese Industrial Standard (is that right?) makes it happen - I don't think there's an 11mm head on the trucks anywhere.
What difference does it make if a hex head won't go through a round hole?
Back to the drawing board, Shane, you'll have to redo every bolt in your restoration!
:D:D
Shane 10mm flat-to-flat. How would a 10mm open end wrench fit on it??:flipoff2: Nice pics though.
Ed
IDave, leave the big guns in the munitions locker;)
There are fours, fives, sixes, and sevens on the head of some Toyota land cruiser bolts. They seem to be related to size, but not always. One of the mildly puzzling things. Probably strength, or hardness.
Shane, you'll want to change out all of your new 13mm head bolts for JIS 12mm ones too. There aren't any 13mm headed bolts in FJ40's either. (rubbing in ;) )
Some info:https://forum.ih8mud.com/showthread.php?t=11324&highlight=JIS+bolt+sizes
Ed, I gotta help Shane out here. I know he has to have these original style bolts for his restoration, not some cheesy futuristic modern bolts like toyota sells now!
Shane, I know a guy with a bucket full of these sweeties who wants to send them to you to restore and plate 'em with cadmium one of these days. :D
The one on the left is a captured version, 24 mm from the base of the head to the tip of the shank. The middle one still has some original plating. The one on right is the REALLY old version you got in the early 60s, with the "4" stamped on it but no inset or circle.
These are closer to 5 than 6 mm in diameter, probably the wear.
OK Fawkers..................I was not thinking what socket to use!!! I was thinking and using my cool little blue tool.
I just ordered a mess of hardware and The head was 11mm tip across to tip. NOT flat side to flat side. But good job at looking at my pics and figuring that one out!!!
The one pic is of an OEM hard top to tub bolt!:flipoff2:
Of course I would know all OEM bolts since I own about 1,000 OEM new ones!:flipoff2:
If you want OEM replated ones, Just tell me how many you need and what you will pay. I have alot!
Have any of the very oldies without the recessed head?
Hardware Porn
Ok DAVE!
Thats IT
Yes send them some day.......I just spent 2 hours glass beading hardware.............It SUCKS
Some Hardware PORN
