Let me start off by saying that I have read and searched and found several similar situations to what my pig is doing but no definitive answer. I Have a two part question.... I will start with some hsitory.
1. 78 2F (desmogged) in a 72 pig carcass
2. Ran fine until late this summer. Would start and idle fine but choke out when I pressed the gas sometimes. If it decided to run and drive a few miles, it would stall out when coming to a stop or slowing down to stop.
3. Had Rochester Carb on it so after careful consideration sent off for a Jim C rebuild (76 Canadian). Gotta be better than the Rosty, right!?
4. Hooked it all up and checked for leaks around base fo the carb and the intake manifold (none), got all the vacuum lines ran to the right place (desmogged so only a few).
5. Starts and idles fine but runs the same. Jim suggested checking the vacuum advance. After further review it is DEAD.
6. Put a WTB 78 dizzy in the classifieds and have had a few MUDDER responses. Most promissing was from ofkilter.
7. He has a 78 dizzy from a canadian pig with part number 19100-61091. Mine is 19100-61100. They look different. First question is will ofkilter's dizzy work for me? If not what would you suggest?
8. Autozone has what they claim is a Reman Toyota for $115. plus core (120)...but if it ends up being the wrong one I am SOL and cannot return it. Seeing as though there are two different dizzys just between Ofkilter and I, it seems a little risky as my experience with box stores are not good. Dealership is a no go!
9. Question number two is if you have any other thoughts of what could be giving me problems.
10. We have done the timing on the pig and the plugs look good. I will check to see if we are at 650 RPM for idle speed, but do not have a tach. It idles great though. I can keep it running in my garage long enough to poison myself. It just does not "roll" well.
Thanks for the input!
randy
randy
