Dan, What steering set up are you going to run? i have my HZ sitting in the frame and it looks like it may be in the way for a sagnaw setup..
Have you tried G&S Cruiser parts for the split case pto drive box? They'd be likely to have one.
I nearly went 60 series on my truck, and wasn't quite comfortable with the mods required. I still would have gone that way had I not come across the Bandeirante power steering box.
Even with that box, which has a large power head on it, the power steering takes a little more effort than I would like, and I'm not sure if this is due to a worn pump, or the Toyota 2H pump's capacity, or what exactly.
I'd be curious to know if the HZ's gear-driven pump might have more output...
Yeah the guy was definitely interested. He had 4 of the engines...I wonder where the other three went?
The progress on your build is moving about as fast as mine. I bought the trans about a year ago and still haven't gotten things going. My 79 series on a 80 frame is gonna be powered by a cummins b3.3t. with the 5spd behind it.
Mderrick...for what its worth I have the a 1hz in a 45 and its running the saginaw box. There is a gm column in the truck. The angle is a bit off but it works.
I have not. I'm not worried about finding one, I'm worried about finding a split case PTO gearbox at a price I like.
Not that Dad's 40 has been out on the highway yet, or with a lot of miles, but the 60 series conversion I did on that feels great around the driveway. I'm also curious if the gear driven pump acts differently or not. I do know that either of our belt driven PS pumps are definitely affected by engine speed. At idle both trucks are really weak, but just off idle it's pretty strong. I don't know if the gear driven pump just spins a touch faster so that it's more like being above idle all the time or not...
Dan
