I have this similar system installed in my truck. I put this system in when I put the 3fe in the truck. The evaporator connections are male flare fittings. I converted to the o-ring style hoses from the 62 using adapter fittings available from advance auto and other places.
The original expansion valve had a manual setting control for the dash but the small tube was broken so I just installed a regular txv.
The fan control is a 4 position switch (off-lo-med-hi), it requires a hot connection to the battery. This switch also supplies 12v to the compressor clutch and the ECU for idle up.
I found a cheap like new condenser on ebay, it is about 13" high x 23" long. It has male flare connections.
I used the receiver/dryer for the 62. The dryer clamp is from a mini truck I had laying around. I fabricated the mounting brackets for the condenser and the dryer.
I used the two long hoses from the FJ62 without modification. The short hoses were made up using the correct ends, one being the flange that bolts to the compressor. A local shop in Wilmington does a good job making these.
One short hose goes from the compressor to the top of the condenser, the next short hose runs from the bottom of the condenser to the dryer. A long hose goes from the dryer to the evaporator at the firewall and the final long hose runs from the evaporator at the firewall to the compressor. I put a few ounces of ester oil in the two coils, dryer and compressor, pulled it down then charged with R134a.
It all plays well together, it puts out cold air. In my opinion, I think the temperature control is not required for this application. I just turn it on high.
I think this unit was made in the us based on the fact the fan inside is made in Texas. This is what the evaporator looks like out of the truck, before I repaired the tubes and replaced the expansion valve.
I have a ac unit for a 40 series similar to the one's shown here this is for a rh drive. I believe, this is a factory unit as it has all the factory plugs for the wiring and uses the factory blower. I have had this unit sitting in the basement for years looks almost new. If anyone is interested send me an email address and I will send some pictures and then you can post to Mud
Bill
That first picture shows the thermostat to the right. It is not part of the TXV. That would have been wired in series with the compressor clutch. The large part of the tube on the end should sit in front coil and cycle the compressor. I'm missing that part from my setup. The TXV is intact. The sensing bulb on the head of the TXV should be charged with the same refrigerant used in the system so it reacts the same to temperature change. I plan on using my in my FJ45LP-B which I going to use a 3FE would be interested in any information you have on fan motor wiring. Missing that switch for that. As for the 3FE I guessing the thermostat should also sent a signal to the ECU to step up the idle when the compressor is running.
Tom do we know what it says on the little red sticker (next to the Save Nature one)
JohnnyC said:I hear you with every point... They are for the most part ... Different ... Very unlikely now that we see these are they oem
