Hot damn... $225 shipped??? That's a steal. What is the anticipated longevity of these carbs? Do they come with any warranty? Thanks
Dan
NORSK--you are where I'm trying to get.
Have you looked into the intake leak issues that seem to come with the header install?
I'm thinking the fix is just to take intake/header to a good machine shop and have them shaved to match.
Are you going to wrap your headers to reduce heat?
did you ever find a fix for this? i am having the exact same problem now with mineFinally got to do a little wrenching after installing my new Trollhole carb--this thing is driving me insane It's idling great but falls on it's face above approx. 1800rpms. Less power than it had before the new carb. Can't find a vacuum leak anywhere, timing is on. New wires, cap, rotor, fuel pump, blah blah. Pops a LOT when I let off the gas. Took the exhaust off right before the converter thinking it may be clogged--nothing gained but noise(this is actually what it feels like to me, a clogged exhaust) Voltage gauge shows low a lot of the time, but I have 2 alt. and the voltage at the battery is 12.5ish. Could this be ignition problems? Is there something I need to adjust on the carb? This is really frustrating! Everybody else is bolting in their new carb and grinning while I'm cursing
I'm running the absolute minimum vacuum hoses. Most everything is already capped or just removed. The only thing I have left that is vacuum controlled is the one hose connecting the vacuum advance to the base of the carb.I'll bring this back up....trying to fix a previous owners trollhole install and desmog attempt.... I'm gonna have a lot of questions.
First one is where do both of the distributor vents get routed to?
