I think the way it is supposed to work is that when the engine is running, vac is pulled on the VCV which opens the VCV.
With the VCV open, fresh air from inside the cabin of the vehicle is pulled through the dizzy cap, into the air filter housing and then into the carb.
When the engine is off, vac is released from the VCV and the VCV closes.
With the VCV closed, fumes from the Carb cannot make their way back down under the dizzy cap, causing corrosion and the build up of moisture.
