2fpower
Wanted to post up the answer. Yes, you can make this plug and play for the ipod connection. You need an "A to A" cable usb. Then you have to doctor up the ends, as it shows on the link..
http://www.tacomaworld.com/forum/au...reo-input-tacoma-aftermarket-head-unit-2.html
Here is the key point that I copied from the link. This also gives instructions for hooking up the data part of the line below the usb on the Toyota part.
1) In the above quote, the OP points out that it is necessary to "slightly push up" the 4 metal contacts. Please note that the 4 contacts are on the Toyota OEM port and NOT the modified USB cable. I used a sewing needle to raise them about 1mm and that did the trick. It is actually safer to raise the pins on the USB cable. If you break one, just buy another of 89 cents at Monoprice.com.
2) When you modify the male USB cable, it is probably not a good idea to remove all 4 sides of the metal shield ground. It is the metal case around the ends of the cable. Apparently, it is crimped onto a braided sleeve that runs to the other end of the cable. It serves some kind of function in preventing EMI or RFI interference. I'm not an electrical engineer, but would rather be safe than sorry. As shown in the picture I left the portion opposite the side with the connectors. It also seemed to help making a firmer connection.
3) You don't need to carve up the Toyota port. If you do so, it might be difficult to form a connection that will not work loose.
4) Before you install this in your car, make sure to plug it into your computer to test it. I uploaded these pictures from my iPhone through the port.
5) Finally, with regards to the AUX cable mod, keep in mind that the Toyoto plug has 5 pins, but the cable you make will only have 3. Basically you are only using the 3 middle pins on the Toyota plug. CORRECTION: Use the 3 pins on the right side (looking from the back). The center one is red and you have a 50/50 chance of getting the other two correct. Make sure to test these buy plugging your headphones into the port and plug the MP3 player into the 3.5mm cable you make. Try flipping the little 3 pin molex connector around and see what it sounds like. One will be much better than the other.
