I've looked at this before and couldn't figure it out. I wanna hook my Hellas into my highbeams..Can anyone steer me in the right direction to solve this. I would greatly appreciate it
I the Hella harness that has the wire that connects to the high beams.. I tried to wire it up to the highbeams but the high beams wire won't trigger the aux lights
Hi LazyYes, the easy answer it to buy from slee. You'll need either the a) lighting harness ($48) and the aux lights harness ($35) or b) the hi beam jumper for $6 and the aux light harness ($35). This is for the high beams to trigger the aux lights. Essentially, all this harness does is run the normal circuit to turn on the lights through a relay, which then turns on the higher current connection from battery to lights. It is a nice plug and play system.
If the OP (anyone for that matter) wanted to replicate, because you know, they're into tech....below is what you would need.
(1) Delphi connector 12059183 $1.80
(2) Delphi F terminals 12077413 $0.24
(2) Delphi cable seals 15324981 $0.10
(2) Delphi TPA secondary lock 12059185 $0.27
(1) Delphi M connector 12084167 $2.04
(2) Delphi M terminals 12048159 $0.22
(2) Delphi cable seals 15324982 $0.10
(1) 30A Relay $1.75
(1) Relay Socket $2.25
You'll also need wire, fusible links/fuse, heat shrink and misc butt connectors. So, with shipping you can probably build for half the cost....If wanting to low beams, the 9006 bulb connectors are 12059181 (female) and 12084166 (male). If anyone really wants to do this, I can draw up a cheesy wiring diagram.....
Post a picture or link to what you have for the hella harness....
hi lazy can you send a link or a picture of the wiring diagram, doing this to my 94 on mon.Yes, the easy answer it to buy from slee. You'll need either the a) lighting harness ($48) and the aux lights harness ($35) or b) the hi beam jumper for $6 and the aux light harness ($35). This is for the high beams to trigger the aux lights. Essentially, all this harness does is run the normal circuit to turn on the lights through a relay, which then turns on the higher current connection from battery to lights. It is a nice plug and play system.
(1) 30A Relay $1.75
