1KZ-TE
About a month ago it would take a cycle or two of the ignition to get it started, if I noticed no glue plug light I knew it wouldn’t crank, if I keyed off then on a few times once I got a light I would turn the starter and she’d run great.
Happened today where it took about 10 on and off got it going.. then I stopped again and it was off for good.
I initially thought glow system, I checked plugs, fuses etc. when I turn my key on the relay clicks, and I get a momentary spike, very momentary on the voltage going to plug rail then drops to 0.V,
I can crank and no start, after running down multiple glow wiring, and even manually jumping the plugs outside of engine to test and then with them in I still get no start.
I cracked a injectors line on crank and didn’t notice any fuel but I’m not sure how much it should be spittting. I’m going back to the truck in a day or two but I’m trying to figure out what to focus on.
I’m leaning towards fuel delivery at this point, but in can’t find anywhere where the spill valve or fuel pump not working would cause the glow to not fire at all… it was fairly cold out but the engine was still warm.
I’m going to check Spill valve relay for operation.
I’m going to try and check some pin outs on the ecu for proper function..
How common is the ecu toast on these?
Kinda a scratcher, don’t want to start throwing parts at it. All initial signs pointed towards new glow plugs but they all burn bright and ohm out around .7r..
the lack of fuel in my last check before I had to leave had me thinking something fuel delivery despite the glow plug light on dash still not turning in at all and in the past once I got that momentary flash, even if it was very short it meant it would start.
