Hope this helps. The prison maintenance crew did this to the trailer prior to me getting it.
Expedition Ops
Now that's a right smart idea that doesn't wreck the lunette or the mount.
Expedition Ops
Welcome back! Looks like you had a great time and the trailer performed well. I'd like to see the new bumper so let me know what the schedule holds.
Later, Steve
Splittilps said:Great Build... Just wondering if you have or could make a vid of how you get the RTT back down to traveling height.
Cheers
prado t said:Wheel spacers.
I had the same problem with my BJ 74 . While articulating the back tires would rub .
Doesn't seem to be any easy solution...but how about lengthen the front and rear fender sections to allow more room...looks likes there's plenty of room over the tire, just the clearence front and back
prado t said:If you dont want your partner to hurt you , I would put a smaller tire on.
Well I am off for a 2 week "Expo " up to the Chilcotin, Towing the MBT . Leaving tommorrow in the early AM.
Hopefully you will come up with a solution by the time I get back.
Any reason why you can't cut the top of the fenders, add a few inches there and take out a little of the sliders on the ends?
Will be almost the same amount of work and your angles can stay the same.
The only down side is you loose some length in the sliders, but gain in the top of the fender for counter top.
Curt
Mcmaster-Carr Part numbers and descriptions.
9416K542 2 Each Gas Spring With Threaded Ends, 29.33" Extended Length, 13.77" Stroke, 50 Force
9416K127 4 Each Gas Spring With Threaded Ends, 60 Force, 22.36" Extended Length, 9.84" Stroke
9416K543 2 Each Gas Spring With Threaded Ends, 29.33" Extended Length, 13.77" Stroke, 75 Force
I haven't made any progress on the trailer, due to the broken collarbone... nothing worse than sitting in the shop and not being able to work!
