so is this only useful for someone with a factory system?
x2 no factory alarm, keyless entry, etc here. Seems like a nice alarm standalone? yes/no? LOL said sure just because the fob is pink.
Not necessarily, the only benefit to someone with the RS3000, is you can cut and use part of its harness. With this installation, you remove the entire factory system and replace it.so is this only useful for someone with a factory system?
FIRETRUCK41, you are a man after my own heart...if I was looking for a man...to take my heart...and I went that way...and you did to...or else it would get awkward...nm.
Good job!
You can use it without all of the remote start hooked up. I think you still need the ignition wire hooked up, for full operation and programming....Can the alarm be installed without the remote start part? I only need it for security purposes , sensors and starter disable.
Good job!
In the picture of the T harness above, the bottom of the T is not visible. Do the wires terminate at a connector or are they cut from the old vehicle?
Do you have to have the T-harness?
I'm about to buy a clifford matrix 1x and am wondering if I can install it myself.
What all is wired into the t harness? The system I bought doesn't have remote start. Just alarm, keyless, and Failsafe® Starter Kill.
It is mostly used for the remote starter. The only reason you may need to access the ignition switch wiring is probably for a starter kill, though you could use the park/neutral indication wires that the RS3000 used for the starter interrupt, in the kick panel area. Do you have a factory alarm/keyless right now?
I thank you so much for posting this, it made me more confidante in installing it on my own even though some of the wires were labeled differently on my truck. Thankfully the old alarm was still wired up so I just basically unplugged all the connections and plugged in most of the new system only needing to find a few new wires.
Maybe sometime ill do a small addition to your write up on how to do it on a truck without any factory systems.
You bet.
Does your viper(clifford is basically the same from what I read) unlock the doors when you turn the ignition off and lock when you crank the car? I find this pretty annoying and think this will lead to premature failure of the lock regulators. I'm sure its something in the programing of the system but I didn't see anything about it in he manual.
