David70FJ40
Older Than Most
Patient - 1970 FJ40, with 2F bell housing and 4 speed transmission conversion. Still has the original 3 speed TC.
Transplant - H55 5 speed transmission with later model split case TC. I believe the H55 will bolt up to the 2F bell housing with no problems and I will have to replace the cross brace behind the TC.
Question - I believe the flange bolt spacing on the newer TC is larger than on the old TC. I would like to reuse the stock portion of the driveshafts from the differentials. (Yes, I know there will be alterations to the length of both driveshafts.) Will the male splines from a later model drive shaft fit into the splines of an earlier model driveshaft.
Any help will be greatly appreciated.
