drive shaft end play
Discussion in '40- & 55-Series Tech' started by landcruiser1974, Oct 18, 2009.
  1. landcruiser1974
    landcruiser1974
    44
    Apr 21, 2006
    oakdale california
    hi everyone i have a 1967 fj40 3 " lift sua with fliped springs its time to get a drive shaft made for it how much spline should be showing at ride its going to be d d mild wheeler hight thanks for your input
  2. dgangle
    dgangle total rice SILVER Star
    4,003
    6
    Nov 24, 2004
    Heart of Dixie
    ask the driveshaft shop that's going to build or modify your DS exactly what measurements they require. Most will just want to know the flange-to-flange dimension. A fool-proof way is to take the truck to them and have them mesure it. That way if it's wrong it's their fault.
    If you are doing it yourself you want enough spline engagement so it won't bottom on full suspension compression or come apart on full droop.
  3. landcruiser1974
    landcruiser1974
    44
    Apr 21, 2006
    oakdale california
    dgangle i am doing it myself but thanks for your responce
  4. dgangle
    4,003
    6
    Nov 24, 2004
    Heart of Dixie
    lots of people make or modify their own front driveshafts when they are used infrequently at low speeds.
    I can hold my own in the welding, fab and creativity departments but I would NEVER consider doing my own rear DS. Not if I ever wanted to be happy with it anyway.
  5. landcruiser1974
    landcruiser1974
    44
    Apr 21, 2006
    oakdale california
    my brother is a top notch machieist welder 25 years exp. no problem for him just need to balance it afterwards
  6. dgangle
    4,003
    6
    Nov 24, 2004
    Heart of Dixie
    so how does he plan to spin balance it?
  7. landcruiser1974
    landcruiser1974
    44
    Apr 21, 2006
    oakdale california
    i will take it to the drive line shop
  8. dgangle
    4,003
    6
    Nov 24, 2004
    Heart of Dixie
    do you take your own food to the restaurant and have them cook and serve it to you?
  9. landcruiser1974
    landcruiser1974
    44
    Apr 21, 2006
    oakdale california
    are you pickin on me dgangle i have more time than money what about you
  10. pbgbottle
    pbgbottle Forum Lifer
    4,553
    Media:
    92
    232
    Feb 8, 2004
    Cloverdale B.C. Canada
    if he gets it dialed in true and straight it should not vibrate . i did my own also .no issues at all
  11. dgangle
    4,003
    6
    Nov 24, 2004
    Heart of Dixie
    I'm just playing with ya. Surprises me they have no problem with it....
    I must have had bad luck in the past because more often than not I have had to re-remove them and take back to be re-balanced...and that's paying a driveline shop that's supposed to know what they're doing. I'm sending my next one to you Jake!
  12. pbgbottle
    4,553
    Media:
    92
    232
    Feb 8, 2004
    nice!:grinpimp:
    i've only done it once and maybe i got lucky ,i spun it around bit by bit as i welded it using a dial indicator making sure it was dead straight. took my time and all seemed to turn out fine. . i found a guy local to me who will do it for $40 bucks cash so i don't bother wasting my time anymore.. he does a good job
    :cheers:
  13. yotawheeler
    yotawheeler
    1,384
    Apr 13, 2006
    Edmonton, AB/Vancouver Island, B.C.
    he should be able to balance nd true it up with a dial gauge on a laith....apperently the old school way of balancing was with a torch, hammer and dial gauge...(i say apperently i have not see it done, pretty sure its long before my time)....however if you search around there are guys who have made their own shafts both front and rear...nd been happy with them. check pirate out as well for how to do ur own shaft...
  14. Seth_O
    Seth_O
    594
    120
    Apr 6, 2007
    Under the hood
    I did my own rear, and I'm NOT an awesome welder/fabricater. Afterwards I took it into a d-line shop (was $50 just to balance it, lengthening/shortening was another $100 on top of that, which is why I did it myself) and they checked the shaft and said it balanced up nice and seemed solid. I've been driving it ever since w/o vibrations or problems.
    It's do-able, just need to be careful and do it right.
