Got exhaust parts ordered and trying to get the little things done so that I can wrap this up.
Got water pump outlet hose made up with two pieces of hose and a barb fitting.
Fits great underneath my intake piping.
Once that was finally done I filled the cooling system as best I could with the rear heater in-op. Adding that to the list.
And needed to turn the truck around in the garage so that I could get the passenger door open more than 10” to finish up the aux fuse panel. Copied @BurntToast idea with the relay and fuse panel, and added relays for ac and the three cruise control switches. Took that excuse to drive around the block. Loudly.
Going to need to move the fuse panel over since the way it is I can’t get the cover off when it is installed. Should have test fit that one.
To-do list:
-Build exhaust
-dry transfer decals on combo switch
-figure out wiring for Corolla cc on/off switch
-Pull vacuum on ac system
-wire C2 43 as negative trigger for ac compressor relay
-wire binary switch into ac system
-re-align dash vents
-finish up battery wiring
-bolt test
-top off transmission and PS
-fix rear heater
-cut rear heater switch into center console
-figure out mounting for center console on top of rear heater
-seal and paint drip rails
-mount windshield washer reservoir
-mount front facing camera
-aim headlights
-schedule tuner appointment
Trucking along. how the hell did you flip the truck around in the garage??
