I don't see why it would. It doesn't add HP just helps fueling and boost. I can hit 25-30 instantly in 4th gear.
With the new settings I can't get over 14psi immediately. Will keep tinkering and also adjusting the methanol pump actuator.I don't see why it would. It doesn't add HP just helps fueling and boost. I can hit 25-30 instantly in 4th gear.
I never was able to to get over 15-18 before and that was never immediate. When I installed the AFC spring I put everything to normal specs as the directions said and it worked great. I lucked out I guess and didn't have to fiddle with the star wheel, smoke screw, or boost thingy. For once I put something together and it just worked so I don't want to mess with it.With the new settings I can't get over 14psi immediately. Will keep tinkering and also adjusting the methanol pump actuator.
You can't beat the investment for the that price.Ordered it. But won't be here in time. I'm headed to San Diego for two weeks.
i don't think the spacers will be the weak link. Are you saving for ARB's?
Don't worry about the spacers.
Locker, stock shafts, 37's, and 4BT?
Drive carefully or decide on on a weak-link and engineer that weak link to make it easy to fix, then carry a ton of spares of said link.
I'm learning real fast that spending what I don't have is the American Way. But yeah it's not gonna be anytime too soon, many other priorities around the house.Your wallet is the next weak link
It's not my place to theorize what will break first- I'm not experienced enough for that. But what I will say is would you rather be swapping out a front axle (~1.5 to 2 hours) or a pinion (many more hours).
That kit looks good for the price. The 4bt I think is slightly lighter than the 3fe
